Although I'm back on a Superjet with stock pump these days, I previously had a 140mm 8 vein (non set back) in my XFT running a Jetworks 6mm BB with total loss.  It suited me perfectly.  It would put the power to the water when the engine hit, and also hook up well in white wash.  The best part about it is that it added very little cornering hookup, so once you initiated a carve/slide/reo with momentum, it was just like stock pump so it wouldn't grip up and high side when you were back on the throttle.
I think the stock pump with the right impeller/nozzle/cone combo is perfect for every day surf riding, but with every man and his dog running the big boy engines these days, it seems they are more of a requirement than a choice.  What's the use of having all that power if you can't put it into the water?
