kickn_it
Super Jet
- Charlotte NC
I have a 2000 RN SJ. Its been running great, no real serious issues until recently. Its not running great in salt water. Last month I took it out in the surf and it ran good for about 10 minutes or so. Then it will bog down, after jumping a few waves or riding the ski hard in the surf. It sounds horrible, like something electrical. The sound is hard to describe but happens every time it looses power. I can pin it and there is no throttle response. However the ski want bog down so bad that it kills the motor, I can idle. After a few seconds of barely pulling the throttle, the ski gets power and runs normal.
Then it will run fine for a few minutes and do it again. I'm running dual bilges and never have this problem in fresh water. I bought a new battery, took it out today in the surf and the same thing happened. It was about 50/50 running good. The issue is coming from the salt water or maybe something is loose and has play. I jump wakes on the lake and its fine. So leaning more towards a salt water issue.
I have a stock motor, bpipe, and xmetal waterbox.
Any Advice?
Any Advice?
