Piston Burner Part DEUX
SkiDaddy
Just Havin' Fun!
Orange City, FL
I'm running a wet pipe, a Limited "B" from factory pipe, so that shouldn't be a factor. I do have my waterbox fairly dry though.
I do wonder if I got some bad gas.....:lightning:
SkiDaddy
Just Havin' Fun!
Orange City, FL
Pipe plumbing is standard - dual cooling to dual inputs on the manifold, front head outlet to a water bypass fitting, rear thru a strainer (gotta keep the pipe adjusters flowing) to bottom of headpipe, top of headpipe to another water bypass fitting. I run a 13/64" restrictor on both head outlets.
Water was coming out both bypass fittings normally both before & after. Temp was just warm. I never beached it from the ramp to where it melted.
SkiDaddy
Just Havin' Fun!
Orange City, FL
Well it appears the culprit is my B-pipe - I have one with the 43mm diameter manifold, which is bad for ported/bigger than 701cc engines.:banghead: :banghead: :banghead:
This makes the front cylinder run hotter/maybe leaner. An easy fix.:smile:
Still gonna do a leakdown test tonight...:sneaky:
kid4now
X-H
Miami Fl
Dont want to sound negative but that doesnt sound like it to me. I hope that fixs it for ya though.
How long have you been running this setup before these problems started ?
Flip the piston over and look on the under side of the dome. Does it show any discoloring (blackening) ?
SkiDaddy
Just Havin' Fun!
Orange City, FL
Been running it 9 months, hammering it hard. I am gonna leak test tonight.
The bottomof the piston is covered w/black goop from the hole in the side. Doesn't look like it got too hot, but hard to tell.
