I just installed a b-pipe ltd chamber, ADA head 35mm domes, and SBT carb rebuild kit on my otherwise stock 2000 RN. Set the carb screws to recommended settings, I also used the new spark plugs as recommended. The jets are 135 main and 75 pilot. The ski runs rough, but won't even come close to idling, and at full throttle it can't even come close to getting up on plane. For some reason I can't get the front cylinder to fire. It seems to me that it is being flooded with excessive fuel. That is my guess because with the new plugs I could tell the front cyl was not burning, but the rear one was. The front plug was wet with fuel, but still looked brand new as if no combustion was occurring. To eliminate possible problems I switched the front and rear plug wires and put a new plug in the front (so it wasn't fouled) to see if the front one would now burn. No go. Still only firing in the rear. My guess is that I have screwed up the carb rebuild and put something in the wrong place causing too much fuel to dump into the front cyl. I checked for spark on the front and rear wires and I'm seeing spark on both. Any ideas on troubleshooting this? This is my first ski and my first Mikuni 38 rebuild if you haven't already gathered that. P.S.The carbs look to be synced very well.
Thanks in advance for any help
