Cost
I can coat pretty much anything with any of our metals, check out the website for examples. As for cost, well thats kind of a grey area, most of the cost is in the prep work, as for the coating itself it is about $100.00 a SQ Ft.
That includes a full high polish and clear coat, I highly recommend the clear coat or you will spend a lot of time polishing:smile: . I would love to get some parts to coat, I have coated my Factory Mod chamber and its holding up with no problems, the metal coating is rated to over 400 degrees.
The prep work is pretty close to prep for paint, with the exception of the last sanding will be a rough 80 grit, so the metal can make a good mechanical bond with the substrate. But I learned the hard way body work has to be perfect because it will telescope through the metal!
