WORLD CHAMP PROVEN GASKETS made fresh daily for EVERY 2 stroke YAM-KAW-SEADOO.Also A/M parts gaskets
caseville9036
BLRider
SE MI
KAWASAKI
7050 Kaw 750/800 Reed (4 req'd) $2.25
7430 Kaw 750 Intake to cases(2 req'd) $3.00
7075 Kaw SX-R 800 exhaust manifold to cyl(2 req'd) $3.00
Hey SJ113,
What is the difference between the 7050 and the 7430 gaskets (I'm hoping that the 7430 goes between the reeds and the intake manifold and are the ones that match the intake manifold opening)
I need -
4 - 7050's
4 - 7430's
4 - 7075's
Shoot me your paypal info and a price.
Thank you
PWCSAR
River Rat
Wa
Glad I found this.. I am going to need 4 750 reed gaskets, multiple carb gaskets etc.. The Reed gaskets being $10.00 each at the stealership makes this really worth ordering extra's... Expect an order soon... Thanks, J.
SUPERJET-113
GASKETS FOR CHAMP BRAP!
Do you have fiber head pipe gaskets for 91+ 440 ? Thank you
Yes... Pm if you need something, thx!
All gaskets made fresh daily! Ah! that new gasket smell and feel! New gaskets do dry out over time and will not crush and seal as well the first time!
We dont stock bins full of gaskets and forget about it. We keep all our gasket materials bagged to keep in the freshness. There is a difference!
Ask if you need something, my list needs to be updated and there are a lot of other gaskets/seals/orings that i have.
See first post with list and prices! If there is something you need that you dont see, just ask. We are always adding dies for new gaskets, so the list is not always perfectly up to date.
Have a great day!
Official Gaskets of the 2011 IJSBA Amateur Freestyle World Champion Derrick Kemnitz Jr. 865cc Xscream engine!!!
SUPERJET-113
Have a great day!
SUPERJET-113
What is the thickness of the yamaha 650/701 head gaskets?
.047" ultimate green synthetic fiber with stainless steel fire rings.
Have a great day!
I can't figure out how to pm on this forum
Anyways I need 4 of 5860 650 intake
2 of 5880 650 exhaust
1 of 5800 650 head
5 of 5460 44mm carb
And a .060 650 base gasket
Also wondering if it is a big problem to ship USPS to Winnipeg Canada. please let me know. Thanks
SUPERJET-113
1 of 5800 650 head
5 of 5460 44mm carb
You have to have at least 5 posts to PM someone. Its no problem to ship to Canada. i ship worldwide all the time.
If you want, go ahead and post on this thread, i dont care. I'll send you a PM with a quote for the above items here in a few minutes.
SUPERJET-113
Have a great day!
I have a 99 SJ with a Riva Girdle head with 35cc domes on a stock motor w/ factory b pipe, jetted stock carbs. My compression should be about 185 but is about 150 both cylinders. This was the case when I first installed it. I intended to get smaller domes but never got around to it. Now I want to bump my compression. I am not sure why the compression is low. The cylinder has never been removed from the cases. With the head off the sleeves look good, normal wear, and the rings look good from what I can see of them at top dead center. Squish test is .050. I believe the oem base gasket is .020. What do you recommend? Do you have a smaller base gasket? I dont think I will find 33cc dome for this head anymore.
SUPERJET-113
Have a great day!
Have a great day!
Cannot figure out how to pm. Need .010 or .020 62t gaskets
SUPERJET-113
PM Sent for several gaskets needed...
PM sent!
Have a great day!
SUPERJET-113
Have a great day!
SUPERJET-113
Have a great day!
SUPERJET-113
Have a great day!
RivMan
doing something stupid...
Pinckney, MI
SUPERJET-113, what is the difference between the 7430, and 7050 gaskets?
Thanks
-Rob
