- marion ohio
My question is why is there a stroked and a stock stroked option? & whats the diffrence between the two? Besides the obvious the stroked kit is for the stroker crank lol. Y is there a diffrence at all?
Since when has there been a ss950?
Strokers require different port timing and when you get to the longer stroke engines dasa and most other engine builders use longer rods to reduce rod angle at front and back of crank revolution. there for the cylinder needs to be taller to avoid having the need for a spacer plate. Honestly anything over +4mm stroke (72mm) should prob be left for competition or SERIOUS hobbyist. Service intervals just get to intense when going anything above +4. +6mm isnt too horrible on service intervals but with a SS950 dasa available now i say stay stock stroke my friends!!!
but to answer your question simply cylinder height and sleeve port heights need to be different for strokers
What would be your personal choice for a strongest(biggest) motor, if you wanted something maintanence free, that hooks up to all the stock accesories of a SJ???
FW, rec rider, possibly hybrid ski this winter, no back flips ever, but enough power to do barrel rolls with ease (180lb) at 6000 ft elevation (about 30% less power). and budget? well it depends how much you spend on the rest of the stuff....but lets say for an example $4000
I might consider, still waiting for a hull deal to come through. Thanks Nuklear6, I will hit you up.I got an 840cc (88.5mm pistons on stock stroke) they pull really good. $2900 for short block with refurbished cases, fresh rebuilt oem crank, new:forged custom wiseco pistons, ada superbore head, custom oversized sleeves
pm if interested
Nuclear6 could you clear up the power valves on the motor, for me.
