Super Jet Pump Body Bolts
I have searched and cannot find an answer. I have a project ski that is missing the pump body bolts that hold it to the ski. I have the part number 90119-10917-00 but was just going to run to Ace hardware down the street and grab some stainless bolts. Does anyone know the length on these? They are the four short bolts that hold the whole pump body to the ski.
Share your info!!
Once you know that you can shim the pump, you know the word to search for. I just read over whatever I could find. New to anything the hardest part about searching is knowing which words to search for. Here is one read over and realized to just shim the rear. http://www.x-h2o.com/threads/54310-shimming-superjet-pump and these if you want a proper shim stack, http://www.shopsbt.com/jetski/37-004-1K.html . More reading, http://www.x-h2o.com/threads/51928-engine-pump-shimming-questions .
Yes that's a stainless M10x1.25x30mm pump bolt.
You don't need a spacer for the 6R7, 6R8, or 61X reduction nozzles but you will need a spacer washer for the trim 62T & 65V reduction nozzles to fit in a pre 07 SJ hull.
What I was know is that is a Wave Raider pump. What I was told is that it is a GP800 reduction nozzle. So the 6R7, 6R8 and 61X are a little thicker material there.
