Blaster OEM 760 pipe in B1?
Mile9c1
X-H2O.com
Grand Rapids, MI
Anyone know if a stock 760 pipe will fit into a blaster 1? I'm planning a 760 swap / conversion (removing a complete 760 from a 'Raider and putting it into a B1). I did a search and didn't see anything about the OEM 760 pipe fittment.
964Chris
FREEdumb obtained
TEXAS
I know there is some type of difference with the bolt sizes on the exhaust manifold.........not sure what they are. I'll try to find the post that mentioned it. other than that I believe everything else will line up (bed plates are the same)
Mile9c1
X-H2O.com
Grand Rapids, MI
I have the 760 engine and exhaust. The exhaust is huge and I know it would require a rear water box. The question is, will the exhaust fit? Also, will the oem flame arrestor (dual 44) fit?
964Chris
FREEdumb obtained
TEXAS
i don't know if you're going to be able to fit that exhaust in there......I'll take a look at my wife's b2 and compare it to my b1. the dual 44's should fit no problem. i have a rear waterbox (from a raider 701) in one of my b1's. very easy mod.
Mile9c1
X-H2O.com
Grand Rapids, MI
The oem exhaust is already on it, plus it is tuned, bulletproof, and best of all FREE. I do have a b pipe on order but it wont be in for at least 1 month.
baldwin ny
it wont fit but it can b made to. it works great in a blaster. good power with no issuse of crapy pipe mounting ang burning of hoses. i did one a few years back. you will have to cut part of the hull on the side to make the pipe fit. yes the pipe is a lil heavy but so is a riva red. you wont even notice the weight.
