FX-1 Ski dies after 100 yards or so.
schicks
Karma Enforcer
West Michigan
Had my FX-1 out tonight. Ski would run 100 yards then engine would die. It didn't bog down..........just died. It would start right back up and run another 100 yards or so and then just die. I think its my ignition coil. Anybody agree? I've also had some issues with intermittent starting problems in the past. Ski wouldn't start, wouldn't turn, didn't even click. 5 minutes later it would start. Is this problem potentially related? Should I replace my relay at the same time I replace my ignition coil?
Jet Set Performance
I just wanna ride!
Cherry Hill, NJ
Are you running an MSD enhancer ignition by any chance? Mine had the same symptoms a couple of seasons ago and found it was a faulty MSD box. Also check the start/stop switch like special fx said.
schicks
Karma Enforcer
West Michigan
Replaced ignition coil and took it out to the lake......still does it. Ran good around the lake the first time then started cutting out again (turns off like i hit the stop button). At one point I couldn't go 20 feet without dieing (shuts off). May be temp related...rode around the lake once fine then it started acting up. Started RIGHT back up everytime after it stalled. Took it home and hooked it up to the hose. Couldn't get it to stall on the trailer. Ran it for a long time too with hot and cold water.
