Anyone know this ebay seller???
Does anyone know this ebay seller: 2.much.nos?
He is selling a bunch of good parts that he has lied about in his ads.
1. He claimed that an ADA Head retails for over $500 then when I called him on it he edited his ad to say $400. Everyone knows retail on an ADA is $349 and if you shop around you can find it for cheaper than that.
http://cgi.ebay.com/ebaymotors/Yama...017QQitemZ270045658344QQrdZ1QQsspagenameZWDVW
2. He also claims you can run pump gas on the 32cc domes that come with that head. I thought 35cc domes were borderline pump gas. He might be buying someone a topend.
3. He claims that a bpipe retails for over $750 new. How come you can get a new bpipe for $630 from Factory Pipe (without elbow hose) and I know FP has them in stock.
http://cgi.ebay.com/ebaymotors/Yama...017QQitemZ270046353212QQrdZ1QQsspagenameZWDVW
I sent the another message letting him know that I was thinking about purchasing a set of 44's, but after seeing the rest of his ads I probably wouldn't buy anything from him
Am I being a d*ck? It just pisses me off when people try and bs buyers to improve their sale.
He just messaged me back and told me he was going off the prices he found on Wamiltons. No wonder they're so high.
I told him he should still check into pump gas on 32cc domes or he might be buying someone a new top end.
I'm about to order a new ada head and I was going to go with 35cc domes cuz I thought I had to. Can I get by with 33cc domes? Would it show a noticeable power gain by going with 33cc domes vs 35cc domes.
tor*p*do
Squarenose FTW
NW NC
I noticed that in all 4 photos of the head assembly, he never shows you the inside of the domes.
without being able to see, I would assume the worst.
hangtime
Speak up ,don't kiss azz
According to ADA you can run the 185 compression domes all day long on pump gas 93 octane .That's what I have with no problems so far .
I also e-mailed him telling him the ADA's go for $345 shipped .He responded with thanks for my 2 cents.
ADA lists the following on their website:
29 cc 230lbs 115 octane
31 cc 215lbs 110 octane
33 cc 200lbs 100 octane
35 cc 185lbs 91 octane
37 cc 170lbs 91 octane
Mile9c1
X-H2O.com
Grand Rapids, MI
depends on your porting, I am running 35cc domes on my sons boat and it is only 167 / 170 comp.
Porting can lower your compression, but just because your gage reads lower doesn't mean you should run more compression because "185psi is safe". There's more to dome size selection than compression. Don't ask me what but 35cc seems to be a good number.
michael950
for me to POOP on!
Houston, TX
I know he is on the boards, I sent him a message to see if he knew about the X. He said he was, but I do not know how often he reads up or posts.
I am sure he knows the true values of that stuff, as he has bought a lot of goodies on eBay.
If you know what you are looking at, then you have an idea of their true retails.
It's just Ebay man, if bidders aren't smart enough to shop around then that is their fault. It's not the seller that determines the final prices it's the bidders. I wouldn't hold his estimated new prices against him.
Aaron
