Super Jet Speedwerx exhaust
I bought a used Speedwerx pipe and tryed to get is mounted on the motor on the bench but there is 5 inches from the head to the mount on the pipe. Am I missing a mount?
SuperJETT
none
There should be a plate that bolts onto your head mounts then rubber mounts bolt onto it.
SuperJETT
none
The rubber mounts are the Lord mounts, this pipe has a platform for 2 of them that bolts onto the head mounts plus there is a 3rd Lord mount that bolts onto the flywheel cover though I normally didn't use it once I got my pipe aligned properly by slotting the bolt holes and angling the stinger over.
Lord is a company that makes rubber isolators, kind of like Kleenex makes tissues.
