Xmetal Pole Installation :: How are you installing yours?
How are you installing your dual breather xmetal pole?
  • Just drill her out and shove the tubes In
    Votes: 6 46.2%
  • Seal up original hole, reinforce, and cut new holes
    Votes: 7 53.8%
  • Total voters
    13
  • Poll closed .
Right now I am running a single hole. Over the winter, I will seal it, reinforce, cut two holes, and go that route.
beachedflunkey
wavejunkies
Virginia Beach
It doesn't take much to seal up the original so I did. If you are installing new xmw hoodhooks then you'll need to reseal those holes too and drill them back out a little further back.
Y
yamaslut
Just wanted to see how people are installing their dual breather poles commonly.
are you sealing up the original hole and reinforcing the whole pole base while you are at it, or are you just opening up the stock hole larger to fit both breather tubes?
so far both boats ive installed an xmetal pole on, ive sealed up the original hole and reinforced the pole base at the same time.
you know what to do
Pat himself told me to just drill the new holes, mount the bracket, take a dremal with a sanding drum, use the bracket as the template and grind away...... there is barely any of the old hole there anyhow.........
