gumper
Gumper
- New Jersey
Anybody know if the 66e motor with a stock pipe will fit in a blaster hull? (I know the motor will... I have the WD conversion kit...just wondering if anybody has tried the stock pipe in a blaster. Thanks!
The exhaust fits just fine and tight , you may need to cut out a small clearance for the carbs and then glass over it , if you do it nice its not noticeable , glass in 2 extra motor mounts , slide in the water box in the rear .Anybody know if the 66e motor with a stock pipe will fit in a blaster hull? (I know the motor will... I have the WD conversion kit...just wondering if anybody has tried the stock pipe in a blaster. Thanks!
that waterbox will fit in if u take out the battery box and do a little trimming u did not have to do it that way lol
