Super Jet Quick Question for a Large Dude
Got the new superjet And am in the process of ordering up all goodies haha But I am 6'2 and 225 pounds of Oreos I am trying to figure out what kind of Prop and Ride plate I should get
I ordered up Factory pipe , works 228 , and a ton of other items Just not sure on Prop and Plate ??? Any help would be awesome
I only ride in lakes and a few rivers so mostly flat haul ass chase down a boat and play then we like to Carve in close to the rock walls at powell while trying not to put a scrach on the new ski hahaha
Thanks every one
i'm 6' 210.
solas 13/17 pulls me fine
i got a skat swirl for my second ski haven't tried it yet, not sure the pitch.
sounds like you'll want some type of extended plate based on your riding description.
longer plates help the ski plane easier, and stay that way. shorter plates cause the nose to ride higher.
hope that gives you some direction.
Tmart
formerly superjet444
Middle Georgia
I'm 6'5 230. When I had a stock RN, I had stock ride plate cut flush with back of hull, and the biggest thing was shortening the pole 3 inches. For prop i had solas 13/18, but the hooker 9/15 is key so go with that
smoofers
Rockin' the SQUARE!!!!
Granbury, TX
I ride a SN but I'm 6'2" and ~240.
Shorter length pole (I run -4.5") makes such a big difference for me.
As for ride plate, I run a shredmaster but was pretty happy with the stock plate. I'm running a 9/15 Hooker.
baxt3r
BBQ
Charlotte, NC
'06 RN
B pipe limited
Worx 201
C+75 12/17 prop
Oem ride plate
Pole cut 4" or 5" (can't remember)
I am 6'2" and weigh about 245. I am happy with what my ski does but would like to upgrade to a larger motor.
