djraider700
lol wut?
- South Jersey
You can move the cable to the outermost hole on the turnplate no problem.  Just whenever you adjust the steering cable or modify anything, make sure that the turnplate hits the stops BEFORE the cable is maxed out.  If the cable is maxed out one way or the other before you hit the stops, it will break.
The turnplates are all the same. The ones you are looking at are great choices.
Hey dmpus, why do you say the stock throttle and steering system wont work with the shmity1 cable? I ran that cable with my stock pole, turnplate, throttle, and nozzle. The only thing i really had to modify is the one hole for the cable block thing. Did he change the cable or something?
