- Orange County, CA
guys give me some direction,
I was out at pismo and kept getting water in my cylinders.
Ski info:
62t/62t raider motor
ADA head
Factory B pipe with 61x manifold.
This my 3rd ride on this motor, was honed with no top end from art at jetworks (suppose formerly of jetworks).
I've replaced the O-rings on the head,
I get even compression, only showing 150/cylinder thought it should be higher but could be a result of cheap gauge.
Motor runs strong dry, put it in the water and kit bogs and dies at about the time it would take water to get through the cooling system and into the motor.
We pulled the head at pismo and saw evidence of water on the cylinder sleeve.
Point me in the right direction. I have a hard time believing it's a head/warped cylinder issue if compression is even.
What else could/would cause this???
Ski info:
ADA head
