we have an engine out of a wetjet kraze and swapped the 650 back into the wetjet with no problems.
now it comes to putting the 701 into the SN superjet and there is a gap from coupler to coupler. we tried pushing it back as far as we can and also tried to use the shims to get it a little closer, but it doesnt seem to get close enough to be comfortable with.. I checked the numbers on the engine brackets to make sure they were the same before dropping the 650 in the wetjet and they both had "6R7" on the bottom of them. we checked our blaster to see if there was as much space between the couplers and it looked the way it should be, nice and close. looks like the same engine brackets.
this is as close as we can get it, moving the shims around, and pushing the mounts as far back as possible.. anyone know why there is so much space there?
