Blaster 61x differences between single 44 and dual 38 carbs
I'm nearing the end of my B1 build and am looking at carb options. I was planning on a single 44 and am wondering how much performance gain I would get if I went with a dual card setup. I know the 62T cases were designed for the dual carbs and the 61x for single, but would it be worth it to set up a dual on a 61x? My setup now is as follows:
61x cases
stock 701 cylinder and pistons
ADA girdled head 35cc domes
factory limited exhaust
carbon tech reeds
solas mag pump
10/16 hooker prop
What would be the best option for a carb setup?
So, is there a big difference between the bn44 and bn46? It would make sense having a bigger bore carb with the mods. Also, do you have similar mods? and would jetting be about the same as for a 44?
BruceSki
Formerly Motoman25
Long Island
I ran a set of dual 38's on my 61X blaster with a protec manifold. I thought it ran pretty well and did better than the single 44.
I'm always a fan of duals over a single. They will out perform a single any day when properly tuned.
However, tuning a single carb is much easier.
I ran a set of dual 38's on my blaster with a protec manifold. I thought it ran pretty well and did better than the single 44.
Yah, but how many times do you tune it?
BruceSki
Formerly Motoman25
Long Island
Pulling dual carbs is more of a pain during that tuning process is more what I am trying to say.
Sometimes they come on and off 5 times till its dialed in.
Ok, I hear that. It can be a pain in the ass to keep pulling carbs to change jets. But once you got it dialed, it should be good.
BruceSki
Formerly Motoman25
Long Island
I figured U were breaking my chops on that one.
I agree though once the tuning is done maintenance is the same as a single. Pour gas in the tank and run it!!!
BruceSki
Formerly Motoman25
Long Island
the dual 38's sipped fuel. Almost as good as a single 44.
I was running MSD enhancer, lightened stock flywheel, and pro-tec pipe. Really basic setup but hit well once i put the duallies on there.
hhh
ive only had one full 61x engine, but going from a stock 44 to a blackjack 46 was a huge gain in throttle response and overall power and i used the stock intake and reeds
Ya, i was planning on sticking with a single so I got the carbon tech reeds. So, it would probably be best to go with a single 46 or maybe 48. If I were to change to duals, I would have to change to a different intake manifold and reeds right?
motoman96
Banned
Lodi Cali
This was my fx1 motor, with the 3.8 gal tank I could run up an down the river for about an hour. The stroker with the BJ's will drink 2.1 gallons in about 15-20 min.lol
BruceSki
Formerly Motoman25
Long Island
No, on the 61x motor you just change the top plate of the intake manifold to go from single to dual carb.
It is a two piece design with the reeds on the bottom plate.
motoman96
Banned
Lodi Cali
Just a different manifold
