Freestyle Factory pipe
N3vrSat1sfied
Military Member
Fort Worth, TX
head pipes and manifold are different. Ive tried a yami FP, with a Kawi FP manifold and the bolt holes will only line up if the chamber went outside the ski. lol
N3vrSat1sfied
Military Member
Fort Worth, TX
Several people run a Kawi headpipe on a yami setup. Usually to help clear powervalves.
Opps I messed up my first post, I meant in reverse, When I went to put a kawi head pipe on my Yamaha engine/manifold (in a 750sx) the kawi head pipe was rotated to far out and was hitting the side of the hull.
Bolt holes will line up just the orientation/angle of the head pipe is different between the two head pipes.
Ran a Yamaha B head pipe on SXR Dasa motor using SXR wet chamber and it fit no problem . Haven't tried kawi head pipe on Yamaha yet but don't see why it wouldn't work fine .
