Freestyle recommended mag pump for dasa 950 8mm stroker in rickter xfr
Hey guys i have come across a good deal on a solas 144mag pump. im running a dasa 950 in a rickter xfr which is only used for flatwater freestyle. my xfr is currently running a stock pump because i spent my budget last year but i always planned on buying a big pump this year. what do you reccommend? go bigger? if not that what impeller would you run? thanks so much!
alright its been a while but im coming back to this thread. im still running a stock pump but i need to upgrade. do i spend the big bucks on a 148 or 150? or do i get a 144. if there is a noticable difference in the two for flatwater riding i will go bigger without question. i am intending to run blackjack 146's or should i do 148's? any input would be greatly appreciated. thanks again!
waterfreak
I had a vision!
s florida
spend the money on the 148mm and run at least the 48's
Im just running a lightweight flyweel and epic ignition, not total loss. art was saying that 46's might be better to go with if i dont have a total loss? i would prefer to go with 48's. what do you think. is bigger always gunna be better? or will the carbs be too big for my 950 with 148 pump.
Arts 46's flow considerably more CFM due to their design compared to most other carbs that utilize a traditional Bomb-sight.
Take a look at BLACKJACK CARB on his website ..... Any questions call the man himself you will not be disappointed
