- Boyne Island
hi im cody, 16 years old and im a diesel fitter apprentice this is my second ski,( first one that needs work) well i got this jetski for a carton of beer, pulled apart as the guy was going to put in a boat, i put the jetski together rode it a few times, it seemed to be low on power so i pulled it apart to find that the back cylinder and piston had heavy scoring, which i believe is to be caused from a leaking crank seal, because when i removed the inspection cover of the fly wheel fuel poured out. it has a 6m6 crank, 6m6 bottom half case, 62t top of case, hot rods conrods, 61x cylinders and a riva high compression head, also can anyone tell me if these are wiesco pistons, also front piston/ bore is almost perfect, also my impeller was grinding on some high spots in the jet unit, and the impeller has no identification letters/numbers, also can anyone tell me if it is possible i could have a 701 cdi with the 650 strator
