Super Jet turf/blowsion kicker footwell install
Spokane,wa
my foothold should be deliver today for my back up ski,i was wondering is there a easier way to remove the hydro turf,so it could be reuse.....
chad
I pretty much love beer
if your Hydroturf was installed correctly , you wont be able to reuse it . but the search feature will help you with turf removal tips, and tools
Dmac80sc
Here
My second time taking off turf. You won't be able to save it. But I used a multi tool with the scraper blade and worked good then used a sanded with 40 grit paper to get off the rest and glue. Just have to keep moving it so you don't go down to the fiberglass.
Spokane,wa
i'll try the multi tool,it's to bad the turf on my ski now is only 2 month old....
try doing a search...
Spokane,wa
i got the turf off and i used the muilt tool and it work great.i received the footwell Wednesday and just installed the footwell today.so far i had cut and gutted the foam...here some picture
sanded the foam to smooth it out
epoxy and screw down till the epoxy dried
exhaust side i had to remind myself not cut the pipe for the exhaust
this what i did to cut the exhaust side i took the first cut on the other side and reverse it
done till tomorrow then fiber glass
what do u think?
YamaCore
Aka Tripod88cc
Hamilton ON
looks pro. the only thing I do different when I install mine (maybe you did it to), is I put 3m 5200, gorilla glue, or something like that on the back side of the hold before I rivet it shut. it just seals it nice and tight so if the glass ever cracks or leaks you still have some sealant behind there just in case.
Spokane,wa
i did put some epoxy resin between the hull and the footholds,well i couldn't sleep so went back out to the garage and sanded down the footwells and fiber glass,pour in the foam....anyway all done now all i got to is turf the tray....
i did leave some rivets in for extra support,just for my security
Spokane,wa
thank^^^^you.so with the late night and getting up late i started the installing the turf...
yoga anyone...used the mat for my padding since i had it laying around.
done with the tray
got done with the gun rails and the footwell using a heat gun to soften and stretch the hydro turf,didn't want to waste my foot strap so i mounted it to the front of the tray
picture of my main ski and the back up ski that i'm been working on to to have a little low end brappppp
