Midlake Crisis
- Bakersfield, CA
Front has more buildup, back is cleaner, domes are very clean. Any thoughts?
@Gil - one full season, a couple months ago I put a regular gasket on instead of the O-Rings as a temp fix.
I pulled the head to put the O-rings back in to bump the compression back up (runs @150 w/gasket, was @175 w/O-rings), and was just concerned that they weren't even and that the back was so clean. I was thinking it might be from water intrusion. The bore looks perfect though.
KTM 434 said it best there are a lot of variables depending on the motor setup. Basically its about right in the rear cyl and a little rich in the front. Check the carb adjustments to make sure front and rearcarbs are the same number of turns on the needles. If you can lean the front a little the throttle response may be crisper and make a little more power.
How about this:
you have no piston wash=lean. My stock SJ looked like this also...I recall an engine builder saying on here before that the 38 carbs are low emission/lean carbs as stock jetted...so this could be normal from yamaha.
How about this:
before cleaning:![]()
after:![]()
How about this:
Yup, those were photos of all stock setup.
that looks like a brand new stock 2011 SJ engine![]()
