- CT
Ski runs great besides the fact I was blowing O rings. Got a new ADA head shell and flattened the cylinders to fix that issue. Rode through a full tank just fine after that. Went out again a week later and about a half hour after riding something went wrong. Didnt have much power and I figured I blew another O ring or exhaust coupler. It had a little trouble starting but worked better with primer. Took the plugs out and the back plug was closed up like the piston hit it shut. Checked compression and that cylinder was low at about 90psi. Other is at 175psi. What could of happened? The motor never ran hot and was tuned very well IMO. I was jumping around a lot in the coppy surf when it happened. any ideas?
62T ported 727cc. Duel 44's. MSD Enhancer. Factory type 4 pipe. ect.
