N2 H2O
Previously Tbone550
- Charlotte, NC
I picked up a ton of stuff this weekend for cheap. There were two complete skis that hadn't been run in a while and a ton of parts. One of the hulls is prepped for paint and the other one is painted with an ac aluminum pole. The one prepped for paint had a viper 7000 in it and the painted hull had a pp 550 with a sbn44, k&n f/a, a milled head, and a bcw intake mani. I have so many parts that I will be trying a variety of setups with the viper motor. My initial setup will be The viper 7000 in the painted hull, dual 38mm keihens, tau ceti f/a's, westcoast pipe, mariner waterbox, aluminum driveshaft, 440 pump w/ a 16* solas, westcoast open intake grate, and an ocean pro finned rideplate. I also got a 550 pump with a 15.5 skat with a bored nozzle and an ocean pro nozzle that I might try. I'll also try the westcoast flat rideplate I got. I dropped the viper motor and the 440 pump setup in the painted hull and poured a little gas down the carbs and it fired right up. I poured a little gas in the tank(came with a ocjs oversized tank) and It fired up and ran on the hose for a minute. The tuning seems dead on. Can't wait to ride this thing, but there is an electrical drain. I'm not sure if it was the bilge pumps, but I plan to test the ebox tomorrow. This thing sounded like a beast last night when it fired up. I'm hoping to get this one running and keep it then piece together the other one and sell it and a few parts and I should have most of my money back out of this. Both hulls, motors, and the two pump setups there were in the hulls are setup for dual cooling. I got everything for $1000. The guy also gave me a bunch of old catalogues and a clymers manual. Here's a bunch of pics of everything.
