I worked 14hours yesterday and the whole time I was thinking how bad I wanted to ride! Had a family BBQ this afternoon, so I decided to sneak a quick ride in this morning. Drove to the launch, got ski unloaded, mixed up my gas, fueled ski up, pushed beachcart over the water edge. All ready to ride! Push the start button....fires up then instantly DIES after about a second. wtf? Crank for 5secs, it will not start. I immediately know something is wrong because this ski always starts up first push with no priming or anything. Drag the ski back to the van, pull spark plug and try cranking. NO SPARK. WTF!!!! Load the ski back into the van and drive back home.
I am running OEM plug boots, so I had just switched to B8ES plugs from the original BR8ES plugs that I installed back in May. No joking 100 gallons I have the same plugs that burned the assembly oil...lol. Now crazy things start going though my head. Are the nonresistor plugs F'ing with the EPIC?? Did I fry out my coil? I did NOT open up the ebox to locate the EPIC programming lead when I had it out on Friday afternoon, so there is no way the EBOX got F'ed up. I check every wire on the start stop and stator for damage...nothing. I start cursing because the only step left is to open the EBOX up. I do that and start checking if all the connections look good, which they all do. EBOX is bone dry, zero signs of water in it. Running out of ideas and starting to imagine having to drop big $$$ on new OEM COILS a new EPIC or other expensive
panic starts to set in. Last ditch I open the fuse holder and find this....
This fuse is NOT blown, it just broken in half! WTF!! The fuse was mounted under the COIL and it could not bang around. ITS 2MONTHS OLD!! Swapped the fuse and instantly spark is restored. Ski fires right up. Drove back to the ramp and threw the ski in. Got a real fun 45min flat session in. Glad it was a cheap fix but that was a mind F. Good thing is that I put the fuse holer in the fuse port so it can be checked without opening ebox. I also put the EPIC programming lead in the same spot so I can switch to the aggressive curve sometime soon.
