So ever sense I did my build I have had overheating going on with my ski. I have searched around to find a answer but have not found anything. This is what is going on.
-The hose from the exit side of the water box has gotten really soft and about to burst. It has fallen off once already.
-The enter hose on the water box got so hot it split and now I have a 2 inch split in my hose.
-I did the trick to put water on the far end of the pipe to see if it sizzles off but it is so hot that it beads off.
-I melter my throttle cable on the water box
-Melted the s/s switch wires to ground out
-The ski runs fine for about 15 min then a loss of power because of the heat. Not enough for me not to ride but I can feel it.
I do have a control valve on the line from the top port in the exhaust to the end nipple on the pipe. It is set up for dual cooling.
I have a 61 top and a 62 bottom, Stock bore, dual 44's, b-pipe, ada head running 93 for the right size domes. I am riding in inland lakes so the water is little warmer then riding on the great lakes.
Now the only thing that I have seen that is different is that my T fitting so that the main flow is to the pipe and the T is going to the pisser. After looking at some pics on here I have seen that it is ran with the main flow going to the pisser and the T going to the pipe. I am sure this wont cause the pipe to get so hot but just an idea.
Let me know what you all think. I am getting upset with how much I am fixing things. It seems like every time I get in the water and ride I end up melting something so it is starting to get costly now..lol
Thank you everyone for your help in advance!
-Kyle
-Kyle
