Super Jet Priming of superjet often, why
denmark
Why should i prime my superjet evertime i have turned it off to take a break, before it can start... even if it is for 3-4 min i have to prime it before it can start again ? and when it is running it starts at the first time every time..?? somebody help me..
tor*p*do
Squarenose FTW
NW NC
rebuild the carb -
could be a pinhole in the fuel pump diaphram
or a leaking needle and seat
First come out on the low speed adjusters about 1/2 -3/4 of a turn and see if that helps, if not you may have to change popoff springs for a lower popoff pressure.
munki63
Epoxy is my duct tape
Canada
Needle and seat would be my first guess, does it still need to be primed if you start it and let it idle for a bit then turn it off? Same question again but running wide open?
Use a pop off gauge and pump it up somewhere below where it pops to see if it holds pressure - 9 out of 10 times it's the needle/seat not holding pressure.
After that it's all in the low screw adjustments
easyrhino
needs more cowbell.
The river
See any fuel linking around the primmer pump? Fuel pump could be pulling air thru the primmer pump depending where the fuel line is "t"-ed.
I had the same problem once, and pulled my hair out trying to find it. It was a small nick in one of the primer lines, allowing air to deprime the main fuel line...check that and the primer itself to see if it's leaking any air.
