FlightPlanDan
Don'tTrustAfartAfter50
- Crescent Beach, FL
Hoping somebody can answer a couch question.
Gonna block off the oil injection and pre-mix the fuel. Done it b4 and it worked fine.
However, the rotax motor has a "rotary valve" and brass worm gear to the crank to drive it for the oil injection.
In the past we've left the oil tank in the ski with the line hooked up to lube the rotary valve.
My question: Is this lube needed? Or can we remove the oil tank completely.
