Super Jet Superjet fuel problems
denmark
Hey. Have a problem with My Superjet rn it cant sail unless i use the primer every 5 sekund.
It has Stock carburators.
Protec pipe - ATP snake head.
Anybody has Any ideas? Thanks. It was My first run on this sj. :/
You should go through your fuel system.
I am assuming you have a RN Superjet with dual 38 carbs.
Make sure that your pulse lines are hooked up right to the rear carb (middle fitting)
Make sure that the fuel lines are hooked up correctly to the carburetors. Bottom fitting is for fuel in, top fitting is for return.
If all that is okay, you should consider taking the carbs off the motor and go through them piece by piece. Pay close attention to the fuel filters inside the carbs (under pump cover). If they are excessively dirty, you can have the exact problem you are describing.
This may be a good time for a carburetor rebuild.
denmark
Thanks i´ll check it.. but when the jetski is on the tote it sounds normal, starts good, can take full trotle only when its in water it cant run...
When it's on the tote, there is virtually no load on the motor. This can hide a lot of carburetion problems. It doesn't need much fuel nor air without load.
denmark
Carburators are now cleanet , almost all gaskets were damagde so new rebuild kits are ordered... so hopely i can roll tomorrow again :)
what size are stock jets in a 2002 superjet 2x38 mm mikuni?
denmark
tor*p*do i have just bought the superjet, but i think its rejetted, their is a 70 pilot jet in and a 135 main jet
and screws are 1.5 turn out both H And L speed screw.
70 pilots, 130 mains, 115g spring (gold colored), 1.5 needle & seat.
This jetting will be horrible with an aftermarket pipe
denmark
BROSS has written this :
Brand = mikuni
Model = oem
Size = 38
Quantity = dual
Main Jet = 135
Pilot Jet = 65
Needle/Seat = 2.0
Spring = 65g/22-25psi popoff
F A type = stock
Gas Octane = 93
Altitude = sea level
Main type of riding = flatwater/boat wake
Would it pass the 10 second WOT test = yes....pipe is set up for bottom end.
Powerband = low to mid
Motor type/setup = Ported 701 61x/62t, b-pipe, MSD enhancer, head-185psi, 6m6/61x electrics, 13/17 solas concord, WW cone, bored nozzle.
Soon to be 771 flat top
and its almost same setup as i am running, so i think the jetting is okay?
smoofers
Rockin' the SQUARE!!!!
Granbury, TX
In addition to the checks everybody has mentioned, make sure and verify your check-valve between the tank and vapor separator is working properly. It should let pressure in to the tank, but not let pressure out of the tank.
denmark
i think the valve is working, because when i open my fuel tank it "says" tshh... :)
No, that's not right. The valve should let air into the tank so that you don't get "tshh" when you open the tank.
smoofers
Granbury, TX
The reason you get the hiss when you open the tank is because the tank is pressurized. Thomasbv, your check valve sounds like it is working properly. It should let air into the tank but not let pressure out. So, if the gas in the tank heats up slightly, pressure builds in the tank and is not allowed to escape since the valve won't let it.
D'oh! Yes, if the sound is from letting air out, it's ok. If it's from letting air in, then that's not ok.
