Another problem in a month. Took the head out to inspect the leak as the plugs had sign of water. Found out all the o rings were melted after only 4-5 rides in one month. Last rebuild I didn't order the set from ADA but used the o ring from hydraylic shop here. Was it about quality of the o ring? This time I'lll put the ones from ADA but afraid that it'lll elt down again.
