- Stouffville, Ontario
Also, Looking into buying some two part foam for behind my footholds. How much do I need? I talked to a place in Toronto that has it for sale, but I feel like I need just a little for how little there is to do.
Re-ran the electrical and cables through the pole and rubber 'grommet'. Also picked up a beautiful chin pad from Steve-UK.
Gaskets too. Finally can say that I am no longer running a stock exhaust. Realized as I went to attach the hose clamp I may have put the coupler on backwards. I assume the groves for the hose clamps do not effect performance nor matter. Correct me if I am wrong.hey man looking good. if the 130 is not enough i am sure i got some 135's. i would put the 132.5 in as it is closer to 135.
looking at the picture i am not sure exactly how you got it but i think it is wrong. lol. i may be wrong to though. the fuel selector switch is 2 in and one out. the out runs to the in of the rear carb. after that you look good until the top out of the front carb, that should be extra fuel going back to the tank. is your motor all the way back?
