SXR Hydrolock kinda/ water intrusion/ stumped
FULL REBUILD. Top End, Crank, Gaskets, Bore, and take carbs apart and clean them out or you'll only get a couple months out of it.
Well, i've gone down the FULL REBUILD PATH. dropped of the cylinders today. getting them bored to 82.50mm. new pistons, new crank/rod assembly, Head is getting .040 milled off.
Hopefully it'll run a lil "HOTTER" with more compression.
