I didnt replace any coils yet, just the CDI. I did pull the spark plug boots off the other day, when I pulled the enhancer, and trimmed the wires. I didnt try it yet though.
The CDI is a coil - it is the spark plug coil...and it is not really a CDI. CDI means capacitive discharge ignition. Which only means the early versions of this type of ignition used a capacitor to store energy (voltage) to fire onto the primary spark plug coil winding. This voltage was something more than 12 volts (conventional point/breaker stule distributor) and more like 300-400 volts. You start out with more and 100:1 windings on the secondary side of the coil gave you 30K to 40K spark plug voltage - up a bit from a 10K conventional ignition.
Our systems don't use a capacitor (unless you have an old roost boost) and the stator coils provide the 300 or so volts to fire the "CDI" coil.
Well you changed the coil which would have to address the plug boot ends so hopefully it wiull work for you. But don't toss that old CDI as it might still be good.
