masterblaster
X-H2
thought it would be interesting to see if moving the pump back 3 inch would give more leverage in surf turns,compact more aerated surf break whitewater and hookup better even in slow speed situations in surf,after seeing how well the xfs did with the pump back this seems like a cheap solution,Im doing it this time with a stock ported pump,with a wb1 drive shaft,because it works with a sj,I have a 142 setback mag im going to try next if this works out as well as I think it will.I still need to have a a drive shaft made for that setup.
This doesnt cost much but its a pain in the ass to do especially with thrust trim.everything is in the way of every single bolt and alot of grinding needs to be done.if you think putting a 148 mag in a sj is rough,look out trying this setup out.
blaster shaft
Uploaded with ImageShack.us
cleanup pump
ported pump
nozzle with tabs welded for org hull holes
add a extra wear ring
little gasket sealer,toss in the hooker.......now thats a setback
ready to drop in
rewelded the trim ring holes solid and kawisized the issue with a older thrust trim to rid the slop,props to Jon for that idea
grinded and shimmed 8 ways from sunday and installed
good bit further out the back now for a little bit more leverage and holding alot more water'
blaster shaft
cleanup pump
ported pump
ready to drop in
