I am not trying to bring things down, trust me I would hope only quality parts ever were made.
just as an example, I am molding an fx hull right now. So far its taken 12 yards of mat, 1 yard of 10 oz cloth, 6 gallons of resin and 12 man hours to just mold the bottom of the hull. its not done yet as its a 3 part mold due to the tubbies being built into the mold.
this does not include all the little things or the time and materials to modify the hull like we have. I still have to do the top and the hood and a bearing support. then I can begin to make the parts. dont forget time to sand and polish everything. its a huge investment.
I could have used a little better materials and I could definitely used worse(cheaper). not including all the time and materials to make the mold I hope in the end I will be just slightly higher in materials to lay up my hull than to buy a ski and mod the pump, add tubbies and widen the tray.
So if you "could" make a hull where the materials cost approximately what a stock hull with mods cost then the only thing left is the labor. I still have so much to do I havent even thought about a layup schedule or if I will bag it. but just for a point of reference using the mold numbers it would take approximately 25 hours just to lay glass. this is not including mold prep, cutting materials(sounds like nothing but it takes more time than you would think) popping and trimming parts. drilling all the holes for fittings.
we have seen all the builds and top deck swaps and that is what lies ahead. Not a very cheap propasition. I know I dont want to do it for 15 and hour. furthermore I cant afford to. this is assuming everything goes perfect lol. or that the builder knows what they are doing and if they are building the best possible product or just trying to pass it off as an affordable alternative. we have seen how that ends.
How many of us would be in this hobby if we had to pay 6K just to get a hull?
Im not scared though, cause if all that was out there was couches you can damn sure bet I would take a sawzall to it and carve me out a 4stroke superjet from that pig.
It would also greatly increase the overhead. And while you may be paying those guys only $10/hr, bet that hour would ultimately cost you quite a bit more.
And as a customer I'm not sure I'd want a hull laid up by minimum wage folk.
Jmho.
(secretly, I hope you're right)
Good thing Rickter fans don't share that opinion. :biggrin:
i think you should go to the factory before you make a comment like that !!! if its good enough for Ferrari , Audi , Ducati , KTM etc etc etc its good enough for Rick to have his hulls produced there , the place is run by German and english guys with all the latest equipment there carbon is some of the best in the world .
i have been there many times a very good friend of mine used to run the place motorcycle dept , it a far cry from a 3 rd world sweat shop
Jmho.
So do you think the guys at the Ski Clinic laying up those Bob hulls are getting paid $80.00 an hour or is it closer to $10.00 dollars an hour ? I am thinking its a lot closer to $10.00 than it is to $80.00........................
Family owned and operated.....can't put a price on it.
Benny
I believe they already did, $3500.00 so you are totally wrong on that one.
lol, i have never seen someone so enthusiastic about the desert... what do you hunt?
The problem is you are looking at it from a Jet ski tech perspective, I don't know what your labor rate is but mine is $80.00 an hour and I am on the low side of scale. You have to look at this from a production standpoint, using that analogy you won't be paying your employees $80.00 an hour, you will be paying them maybe $10.00 an hour, at that rate 25 hours of labor is $250.00, materials will be much cheaper because you would be buying large quantities, 55 gallon drums of resin, giant rolls of cloth, etc etc.That kind of production facility would put the products in a more affordable range.:wiggle:
