swapmeet
Brotastic
- Arlington TX
I have a FX1 Hull that I plan on reinforcing/ modding this winter.
I'll only be riding flat water, and the desired result is a ski that increases my ability to do tricks etc. This is strictly recreational. I love what the XFS from Rickter can pull off, so i'm kind of using that as a 'guide' of sorts.
My thinking is that I can modify my hull for a couple hundred dollars worth of materials and 'build' a pretty slick ski on a budget vs. dropping a ton of cash on a bare aftermarket hull.
The list of mods i'm considering is as follows:
(All mods will be with biax glass and epoxy resin)
My plan is to stick a warmed over 701 in it, ~95hp. Hopefully that coupled with the big pump should yeild a decent ski on a budget.
Am I on the right track or wasting my time? Has anyone else performed any of these? I know Superjetbrett has a pretty wild ski with these mods. Not sure if he'll make it in here to comment.
I would beg, borrow, and steal to have a XFS, but I doubt it will ever happen. I just don't have the spare cash.
So what do you think?
- 144 pumpswap with shoe
- Reinforce sides and bottom of engine compartment
- Move pole mount forward and reinforce mount area
- Shorten rear of ski ala' RRP XFS
- Tubbies
- Widen Tray with Holds and/or straps
- Defoam, probably replace with ping pong balls
- Possibly reshape rocker to shorten
