I'm sure there are a multitude of reasons, but for one a sled has a
cvt that allows for a much more narrow power band which naturally leads to higher peak numbers. Skis are obviously
direct drive which means they need to make good power from right off of idle (especially for freeride/style type riding) to peak rpm. You could put a cvt in a ski but the pump design would have to be totally different from what is out there currently to efficiently use that type of power. Unfortunately our sport doesn't have enough money in it to support the R&D effort and tooling expenses needed to get something like this off the ground.
Somewhat related, I have day dreamed before about a coupler that stores energy briefly (in a torsion spring for example) before delivering it to the mid-shaft. It would delay but increase the initial amount of power (ie hit). The idea could work but again all that additional power would likely be wasted in the form of cavitation unless you had a pump designed to take advantage of it.
