DaUpJetSkier
I like square
- Marquette, MI
topic says it all, what and why? Im going to be building a 61x/61x motor this winter, freestyle ported jug stock bottom end with 6m6 crank stock 44mm carb, hopefully b pipe or something close, and dont really know what to do on the head, stocker milled, aftermarket if so what brand, there are so many and want something reasonable price and the max psi that is still very safe, 150-180???
Stock reeds will be fine right?
Can I reuse crank seals or should I get new, they're from a 93 650
obviusly full new gasket set
How about wrist pins, bearings, cir clips, can I reuse?
The pistons are used pro x, .75 overbore
Please give any other engine build info that I may need or links to other sites on tips on what to do and what not to do.
Ive helped build two 550 piston ports and did a 650 kawi but it was half ass and didnt care as much as I will with my own ski. THANKS
