Yamaha Parts: 62t Top end + misc.
62t top end pulled from a running waveraider with 150 psi per hole. Has sat in bag with oil for about 2 years as a back up. Can take more pictures if required. - $old
62T steering nozzle painted red. Paint chipped in a few spots. Drilled for quick steer. - $15
White Yamaha gas cap - $5 each
Prices do not include pp fees or shipping. Shoot me an offer.
Solas 144mm 12v mag pump tapped for dual cooling with pre-08 length superjet driveshaft and 9/15 hooker. $old
I bought this setup 2 seasons ago with blown bearings. Took it apart to find out previous owner didn't use any form of lubricant on bearings and they overheated and failed. Bore was checked on cmm machine upon disassembly to ensure it was in spec and not plagued with the Solas curse (it was in spec and will post measurements when i find the sheet). Pump was rebuilt with oem seals and koyo bearings using the heat/cool method.
Pump and prop are in great shape. The drive shaft does have 3 damaged splines (pictured) slightly rounded. But I ran it like this for the 2 seasons I have owned and they didnt get worse. Bearing spin smooth. May separate for the right price.
