For sale. Yamaha SJ or Blaster drop/tilt nozzle. This was a custom made nozzle (I was told for Jacobs in early/mid 90’s) before Protecs. I cleaned it up and made sure it fits an oem pump (came on a boat with 140mm mag). Now it’s same opening as OEM. 83 nozzle exit. Can be bored to at least 90mm. Very thick at end. Comes with a cable I need to pull from a blaster. Don’t have lever of the screw for cable end.
This nozzle can be made fixed or tilt so if you want 85mm+ bore it’s easy.
$100 shipped in usa.
