Super Jet Yamaha 650/701/760 OEM Crank Bearing and seal part numbers
OCD Solutions
Rentz, GA
I've dug for this information before and found it scattered all over so it's time to put it in one thread and then add to the Tech section once we finish up any corrections or additions.
Yamaha 650/701/760 OEM Crankshaft part numbers
Main Bearings
Mag bearing #93305-30601 32x72x30mm ? Set Hole
Inner (x2) #93306-207U2 35x72x17mm 6207 Set hole
PTO bearing #93306-307U3 35x80x21mm 6307NR Set Hole/Snap ring
Main Seals
Mag oil seal #93103-32M01
PTO oil seal 1 (inner) #93102-36M33
PTO oil seal 2 (outer) #93101-36M46
PTO side Driveshaft Collar #62T-45527-00
Connecting rod
Main bearing (x2) #93310-525U0
Main bearing washer (x4) #82M-11685-00
Wrist pin (x2) #61X-11633-00
Wrist pin spacer (x4) #90201-20M04
Wrist pin retaining clip (x4) #93450-21053
3 finger Drive Coupler
Motor side flange coupling #6m6-45813-32-8P
Midshaft Side flange coupling #6m6-45813-22-8P
Rubber Coupling #61X-4581J-00
Does anyone have a part number for the Mag side bearing for NTN, SKF, Koyo, Fag, etc for the crank I believe I have found a Koyo part #294993 or S-83B207-9 C4 AAB
Mag bearing #93305-30601 32x72x30mm Set Hole Koyo # 294993 S-83B207-9 C4 AAB (to be verified)
Inner (x2) #93306-207U2 35x72x17mm 6207 Set hole NTN # 6207-2RZT9/HC5C3WT
PTO bearing #93306-307U3 35x80x21mm 6307NR Set Hole/Snap ring NTN # 6307 * Snap ring #SP80
OCD Solutions
Rentz, GA
I'm upgrading the bearings in my test bench and need the dimensions to design the adapter sleeve for the conversion.
I don't ride cause I spend so much time supporting those that still do. ;)
