WELL I TORE INTO IT TODAY , PULLED PLUGS THEY HAD NO MOISTURE WHICH I THOUGHT THEY MIGHT AFTER 24 HRS ,CHANGED PLUGS ANYWAYS , FIRED SKI UP NOTICED SMOKE UNDER HOOD ,DIDNT SEE ANY YESTERDAY, I WAS SURE IT WAS WATER AFTER DOUCHEING IT , CLEARED IT OUT ALL HOSES TIGHT ,SMOKED UP AGAIN , NOW IM SURE SOMETHING F3333D UP ,TORE OUT EXHAUST ALL CLAMPS TIGHT, RUN HAND UNDER SMALL HOSE AT END OF PIPE '' BLEW OUT'' ! HAD ONE IN SPARE PARTS FROM PREVIOUS OWNER ''SX2PRODUCTS '' BACK TOGETHER AND RIPPIN ! ALL HAPPENED RIGHT AFTER A HEAVY DUMPING, I GUESS THE TIMING WAS PERFECT '' WHATEVER '' THANKS FOR ALL THE GOOD IDEAS , ILL USE THEM ! PS: I WAS POSITIVE IT WAS WATER ???????? IT WOULD RUN BAD FOR 1 MIN THEN CLEAR OUT ,THEN RUN BAD THEN CLEAR THEN RUNBAD AGAIN ?? NOW I KNOW !:arms: :arms: :arms: :arms: :arms:
