Sometimes when I push the start switch, the engine doesn't turn over and all I hear is a click from the solenoid. Sometimes it starts fine. Things I know:
The engine is not locked.
The solenoid works fine.
The start switch works fine.
The battery is 'fine' 11.4v.
When the starter doesn't engage, I can tap it and then it works.
The connections on the outside are all good.
I took the starter apart and found corroded brushes, etc. so I cleaned it all up and reassembled it. The starter worked great on the bench and it worked fine on the engine for a while but now it's intermittent again.
Could the rear of the shaft inside the starter not be grounding well? Is there another place I should check for a bad ground?
