x2 bilge pump questions
i bought this x2, it has the bilge pump mounted behind the motor by the dshaft....does anyone have tips or pointers on how to get to it w/o pulling the engine ? or maybe mounting a new one somewhere else ?
Crab
thanks darin...noswad!
Seattle
long arms, it can be done but its a pain. Thats why I installed 2, in case one goes bad during the season.
Vumad
Super Hero, with a cape!
St. Pete, FL
My bilge pump was just wire tired when I got it. Well, not a wire tie... one of those brackets that screw tighter like on the rubber for your gas tank... not sure what they are called. Anyway, they used one of those and tightened the bilge to the support. It looks like it was pretty solid and wouldn't go anywhere even after a beating.
Snackem
Danger Zone
Colfax WA
If you pull the carbs and/or the exhaust pipe you can get to them, barely, it really does not take that long to pull the engine though and slide it foreward, even just to the point where it is up against the gas tank.
wadman
wadman
winsted CT
hose clamp
Nefarious
Can't... Stop... Modding
San Diego
Yup, if you pull the carb off you can reach the bilge pump.
