the x2 is a 91 model i fitted it with a 750 out of a xi i used the whole lot
the other day i was hooking up bilge pumps when i blew the fuse in the electricall box
so i replaced the fuse and was fine untill i stuffed around with a switch for the two bilge pumps again and blew the fuse again
instead of replacing the fuse again ( i took the fuse out and went to poke the wires back threw the hole ) untill iwas finished with the pumps
but in doing so the wires have earthed out on the electricall box blowing something else
i have open the electric box and cant find any more fuses
WOULD IT BE THE RELAY THAT NEEDS REPLACING ??????????????????
Or does any1 know what the problem would be thanks
