X-metal steering stuff on AC pole?
SUPERJET-113
GASKETS FOR CHAMP BRAP!
This may have been asked before, but will the X-metal steering system fit on the umi on a AC pole? Also on the site it shows the turn plate with the straight bars. Do they come with the plate? I dont see the bars separate. I would like a set of those too.
TIA
F
Freestyleriverrat
Guest
It should.....I think it is just a different turnplate with straight bars. I put a -1 inch turn plate on my AC pole on my squarenose and had to modify the pad b/c it would hit, but the roundnose pole has more clearance. Turn your bars and see how much clearance you have now and that should tell you if you have to modify anything.
