650/X-2 X-2 750 swap
I have a 1987 X-2 and i want to put a 750 motor in it. Does the 750 fit right in or with existing pipe and carb? What is all involved in the swap?
Mr Bojangles
Lord of the Dance
A search will tell you everything, but a 750 will bolt right in. The bolt pattern for the exhaust is the same for the 650 and 750 but the intake is different. You will want to use a 44mm carb or bigger and a good aftermarket pipe to wake it up and ss impeller. The ebox for the 750 won't fit so most mount it to the side of the fuel tank
Mr Bojangles
Lord of the Dance
Here Is a picture of my setup
