Milled head 190 compression on rebuilt engine 93 octane single carb 61x factory mod pipe fresh carb rebuild primer installed removed choke stock f/a to keep water out.rule 500 bilge and bracket solas prop stubby freestyle cone pump is bored out extended r&d ride plate worx scoop grate dual cooling 2 pissers pipe is from orig owner very clean no salt water has been in pipe has blowsion t screws new OE water box new hood seal new paint job new turf shaved and recovered seat dakine foot straps new battery new starter solenoid pro taper bars PJs finger throttle new start stop switch I think that's about it
Sent from my Z932L using Tapatalk
